Good morning,
I am an Italian, owner of a Tullio Abbate that mounts a 3.7 LX, 470 mercruiser engine.
I use the boat in fresh water on Lake Garda.
I found this forum very interesting because it is full of very competent people and many of you have the same engine.
I write because I have problems with the temperature, when I go to 2000 rpm and 3000 rpm the temperature is stable, slightly higher than the average, when I stand still with the engine running the temperature rises a lot, the coolant flows out of the riser and goes into the container in plastic, a little liquid also comes out of the riser cap and starts to smoke in the engine compartment ... after having cooled the engine all the water from the plastic overflow container is sucked into the circuit and returns completely to the riser ...
What do you think it can be?
Sorry for my writing ...
