Mercruiser 485 3.7 Holley Carb?? anybody seen this?
billywhizz
I decided at 25 years old and no success with the rebuild that my carb needed replacement, Holley carbs seem to have all the:confused: good references, so i made a few enquirys only to be told that there is no Holley carb that will fit a 485, Dissapointed , any body know different?
Re: Mercruiser 485 3.7 Holley Carb?? anybody seen this?
Ayuh,..... No surprise,... Mercruiser doesn't use Holleys...
zbnutcase
Thats correct, a Holley is too long to fit as the carb sits sideways. However a Edelbrock/Weber AFB should work with an spreadbore to squarebore adapter. 'nutcase
billywhizz
Right, gotya, so is the Edelbrock a more reliable and consistant option than mercarb or rochester? thanks
mdlee
I had my 2 quadrajets for my 3.7ls rebuilt by National Carb in Jacksonville Fla. They came back like NEW!! it cost me $175 per carb. Check out there web site www.nationalcarburetor.com. Good luck
zbnutcase
One big advantage of the Edelbrock/Weber (and Holley) is the availabilty of tuning parts. Most Q-Jets tuning parts NLA and Mercarbs almost impossible. 'nutcase
billywhizz
thanks for your reply, i have checked out the Edelbrook carbs and the smallest marine carb i can see is 600cfm which is twice what i need, will this make it a no go situation?
Ayuh,... It'll be just Fine once you tune it....
The old Roctesters were something like 850cfms....
billywhizz
That will do for me, wey hey lets give it a go, will keep you posted, thanks for the reply.:)
billywhizz
ZB, thanks for your reply to my other post,looks like i am running out of options, i made a few enquirys about edelbrock carbs but have just been told by Vic hubbard that i cant replace my 2bbl mercarb with a 4bbl edelbrock, why? is there any other options?:confused:
stonyloam
You could go with a 4 bbl Mercruiser, with a (rare, hard to find) 4 bbl Mercruiser 3.7 manifold.
zbnutcase
Yours has a 2bbl carb? That changes everything! You could then use the marine 500cfm Holley (Holley P/N 0-80402-1) with a adapter. I could swear the 485 was a 4bbl, but who knows decals are easy to change. 'nutcase
Don S
The 485 used a 2bbl carb, circa 80 - 82. The 488 was the first of the 4bbl carbs circa 83 - 84.
zbnutcase
Ah, thanks Don for the refresher. It was the 488 I was thinking of. 'nutcase
