lrdchaos
- Feb 11, 2008
- 265
I have a tahoe q71 with a bravo 1 1.62 gear ratio outdrive, 5.0 mpi. It came with a 19 pitch vengeance, I swaped that out for a 17 pitch 14.25 4 blade solas. I have a chance to pick up a 19 pitch 13 5\8 high five prop. My question is will I be able to run this prop? My concern is that I tried the 14.25 19 pitch solas and could only turn it 4500 rpms, I turn the 17 pitch 4 blade at 5250 at wide open throttle, so I'm a little overpropped. Would the difference in diameter, being that the five blade is smaller make a difference in rpm? Thanks
Also the 5 blade is vented, and my 4 blade isn't, what is the benefit of the vented prop over the nonvented prop? Thanks
