Bought a '92 Cobia Monte Carlo 198es with a Mercruiser 5.0 fed by a Mercarb 2 barrel. I am going to keep this question general in nature as its more of a generic type of problem in my mind rather than a carburator specific problem. I took the carb off of the boat after I bought it because it was hard to start after it warmed up,the choke was stuck open (electric thermostat style choke at top left of carb looking aft) and it wouldn't idle. I removed the carb because upon further inspection with the flame arrestor off when I shut the key off it would begin dumping fuel onto the throttle butterflys (from the mains into the veturi, not the fuel pump spill over). The carburator was rebuilt when the previous owener had the boat. I know this from reciepts and obvious new parts and gaskets.
The inside of the carb was clean, very little crud at all but I gave it a good cleaning and blow through anyway. I removed the entire choke assembly because it would not free up to the point I thought it should be. So I got that working well. Next I found the float level way off so I adjusted that thinking that may be the answer to my problem as to why it was dumping gas into the carb after shut down. While I was tinkering with it I found a great rebuild video on youtube from Mike at Mikes carburators in Wa state I believe it is. Anyways he has a bunch of videos on youtube and a websight full of carburators parts and tips. Just google him and you ll find him. In the video he mentions that rebuild kits come with both a solid and a spring loaded needle valves and if your having trouble with flooding situations go to a spring loaded valve. Well my carb has the solid valve currently in it, Im wondering if anyone has experienced this problem and remedy before. I found the part on his site very easily and ordered it since it's only $8.00 needle and seat. It was a stretch but since I am waiting for the part and I had adjusted the float I decided to put it back together just to see if the adjusted float alone fixed the problem. Well the choke works good and it idles like a top now,comes off idle nice and clean and revs up good. The flooding problem is now there intermittenly. Seems like when I shut the boat off and don't make any movement I can turn the key and with the throttle locked in the idle position it with fire right up and purr like a kitten. If I move around the boat (mind you it's on the trailer) and cause some bouncing you can see fuel again start to spill and it requires a full throttle start to get it going but again it idles fine.
Anyone ever experience this problem before? I am pretty confident this new spring loaded needle is gonna do the job I was just curious in the meantime if anyone has had this happen to them. Thanks in advance!
