LiquidAssets72
- Aug 16, 2021
- 5
Long story short, I picked up a 1989 Arriva 2050. Boat is an open bow with a 5.0 220HP Mercruiser and Alpha One. Got the boat fired up on muffs, checked for leaks etc. Got it on the water and I was letting it get up to temp and keeping an eye on it, and an old JB weld repair someone had done on the port manifold sprung a leak and re-cracked. I jumped for the key, and just as I turned the key off it puked milky oil out of the PCV breathers. Boat was running at a high-idle (900-1100RPM) when I shut it off. Looking for advice on next steps and what to look out for. I am hoping that by immediately shutting it off, and catching it quickly I am looking at pulling plugs, removing water from cylinders by cranking, and then flushing everything out very well? Should I use some sort of fluid like Marvels and coat the cylinder walls when I pull the plugs?
I found a good deal on OEM manifolds, looks like part #860246Q11. I plan on replacing both just to do it the right way. Should I replace the risers as well? I am thinking it makes sense to go ahead and buy risers as well, but curious for someone's opinion with more experience.
TIA for any help!
TIA for any help!
