Jturner1167
- Jul 26, 2016
- 6
My boat had been running fine and developed an oil leak around the oil pan gasket. I had the gasket changed in the boat without an engine removal and now the boat will only run 15-20 seconds at a time. It does run fine as long as you pour gas into the throttle body. If you go out and crank the boat for the first time it will start fine with no issues. The more times you try to start it the less fuel sprays out of the injector until eventually the injectors don't spray enough fuel to start the boat. The fuel pump does turn on when the key is turned to the run position. Any advice would be greatly appreciated.
