norcal racer
- Aug 18, 2010
- 13
i am working on a 1998 mercruiser 5.0 efi ( not dfi ) it had a fuel issue at first was not getting fuel. i replaced the high pressure cool fuel pump first helped but would only run a couple minutes and run out of fuel. i added a boost pump to supply fuel from tank to high pressure pump and that problem is solved. now the boat runs perfect up to 3/4 throttle i think its about 3500 rpm and then starts popping up through air cleaner, any thing below it will run clean and smooth all day. you can hammer the throttle to get on plane but after a short time it starts popping until you back off the throttle. i disconnected the tack wire just to see but did nothing to help. also i changed the two tbi injectors,cap,rotor,plugs did a fuel pressure test, hooked to merc scan tool and no codes checked the voltage on the tps and its fine. i am out of ideas
