FabienLamour
- Jun 3, 2018
- 28
I have been having issues with my 2007 Mercruiser 5.0L since the spring. I purchased the boat last fall and it appeared to be running fine when I baught it, but was a bit lazy.
so I replaced:
- engine oil, filter, gear lube
- gas filter, emptied gas tank because I had water in my gas
- sparks, wires, rotor, cap
- idle speed control motor
- impeller
i got the entire cooling system cleaned up.
my engine cuts off randomly with the audible safety beep. More so at higher RPM, lets say over 2000. It idles good and starts just fine. Sometimes i can ryde for 15 minutes without any issues.
i am desprate beause i am over a $1000 in repairs and still have the issue.
what can it be?
thank you for your help and advice.
OW689770 engine serial number
OW895836 Alpha drive serial number
so I replaced:
- impeller
what can it be?
