Southern Transplant
- Jun 26, 2019
- 7
Can't get up to speed. Bogs down like weeds on prop.
History... Boat is new to me. I replaced boots, lower shift cable, gimble bearing, rebuilt mercarb, new Fuel level sensor, water separator.
With boat on trailer bow up, pumped gallon of gas, found about an ounce of water. Pumped a second time found couple of drops.
Ran engine, idled an reved fine.
Took for test drive for 3 hours. Ran Great!!
Took on vacation a week later... Put boat in water and ran for couple minutes. All good.
Took friends for ride, didn't want to get up on plane. Repositioned load and got up and running.
Performance deteriorated over next half hour.
Dropped off friends, still couldn't get up on plane.
Checked spark plugs, all clean.
Adjusted choke, not sure why at this point lo
Changed water seperator, Note. No water or contamination in gas from filter.
Test drive... Ran great for about 3 minutes. I stopped to pick up some debris in the water.
Could not get back on plane.
Back at home... New water seprator again. No contamination or water found
Checked fuel tank pick up, all clear no cracks,
Replaced fuel line.. Cut the old line in half to check for desalination. Saw marginal buckling on the inner wall.
Removed fuel pump and lines, all checked clear.
Tested pump for 10 minutes. Ran great, no failure
even when wiggling wires.
Ordered new Fuel pump any way, also new plug wires
Worthy to note... After checking plugs I left a wire off, didn't make any difference when I replaced it.
Also, choke is wide open whan warm.
Any ideas? What am I missing?
Crazy about that 3 minutes of good run time.
Sorry for the Novel
Sorry for the Novel
