mercruiser 5.7 Closed System Hose questions
Rsims62
HI Everyone,
I posted on the wrong forum, so hopefully this is the correct spot.
I have a converted closed system on my port engine, Besides stat housing missing , the stat cover is there all filled with silicone and didnt leak believe it or not, but it needed the correct housing ,which I have coming.and some other rigged items the PO had done, I have a issue with how to correctly connect the cooling hoses.
My heat exchangers outlet s are on the right of the engine going to the left to the circ pump!!! See Pics. So the PO had copper pipe and hose and tie wrap to keep them from touching the pulleys. I looked everywhere and went to several marinas and No One had a answer!! for molded correct hoses?
Can this stay as IS? It worked but how should it be done correctly..
