Hi all, was looking for some help identifying my v8 Mercruiser engine. I know this is a topic that has been covered extensively but I'm still confused lol. I was told by the PO that the original 5.0 was replaced with a 5.7. I was able to find a tag on the valve cover but the serial number is illegible. There are no other tags on the motor. The casting number is 14093638. I'm looking to replace the Volvo Penta manifolds and risers that are on it with the correct parts as well as sort out the cooling lines that are blocked off at the thermostat housing. The boat is an 89 Larson DC 200. This was my first power boat and through all my research and dollars spent I know the PO knew just enough to be dangerous. I'm horrified I ran the boat with these incorrect siliconed risers for two summers!!! Any help on the motor ID and the correct cooling system setup would be much appreciated!! Thanks!!!
