Re: Mercruiser 5.7 maxing 4k rpm Prop incorrect?
I am having the same issue. Here is the completed form as best as i can do it right now.
1. Year, make and model of boat
1991 Wellcraft 233 Eclipse
2. Length, width and base weight of boat, look for boat decal on back of boat
23.5', 8'6" beam and I am guessing around 5000lbs with me & 1 person on board as normally used
2a.What is the maximum recommended HP for your boat
Don't know for sure, but it is a 330hp 1996 350ci mercruiser engine from eagle engine sales.
3. Number of people and gallons of gas normally on boat
2 people and about 35 gallons of gas
4. What do you use the boat for
Cruising and anchoring out
5. Is it a Deep Vee and if so how many degrees of deadrise
I am not sure
6. Year, make. manufacturer and model of motor
1996 mercruiser 5.7l 350ci
7. HP and gear ratio of motor IMPORTANT
330hp (advertised) probably more like 300hp. 1.5 gear ratio in alpha one replacement drive from sterndrive engineering.
If you don?t know the ratio, you need to pull the plugs out and put a piece of tape a c ross the prop and the lower unit and then cut it between the prop and the housing and turn the motor until the tape lines up with each other, it is easier if two people do this, so one can watch the prop while the other counts the revolutions of the motor
8. Manufacturer?s recommended Wide Open Throttle (WOT) range
4400-4800
9. Anti-ventilation Plate height above keel of boat if it is an outboard in inches, use a board under the keel and stiking out to the anti ventilation plate for a referene
Not sure
10. Is it a bass boat or does it have a pad bottom
it is not a bass boat, I am not sure what a pad bottom is
11. Does it have a hydrafoil, dolefin or trim tabs
It has a dolefin, SE300
12. Make, model, diameter, pitch and whether SS or aluminum prop
QL 14.8 x 17 3 blade aluminum prop
13. WOT RPM and speed from your current prop and how much gas and how many people were in the boat for the test data and is the speed by GPS. Make sure you trim the prop up until it starts ventilating and then just trim in until it quits ventilating. If you do not have a tach you can buy a Tiny Tach for $ 50
RPM - ~3900 Speed 42mph No. of people 2 Gas 20gallons
14. Are you at sea level or a higher elevation, give us the elevation in feet
Sea level (florida)
15. Has your motor been tuned up lately and have you checked that the carburetor butterfly is opening all the way, checked compression, and looked at the plugs and checked spark, all of the foregoing could be the reason your prop is not attaining full RPM
New engine with about 6 hours on it
16. How long has this prop been on the boat and why, at this time, do you think it is the wrong prop
Prop has been on there for a while, Installed new engine and new outdrive. I think it is the wrong prop because i am not getting above 3900 rpms, and I can feel some vibration when it is in gear. No vibration when it is in neutral.
17. Does the prop show any damage that you can see
Prop shows light damage. Some knicks and dings.
18. What problems are you trying to cure or what are you looking for the boat to do that it is not doing the way you think it should or to your expectations
Trying to make sure I am not overloading the new engine i just installed. I am pretty ok with the speed, Just want to make sure i treat the new engine well.
19. If you are trying to attain a better cruising speed and fuel savings or trying to attain a faster speed I will want you to take your boat and run it with 1 or 2 people and give me the RPM and speed readings starting at 3,000 RPM in 500 RPM increments all the way to WOT.
I can do this, but I don't really want to run the boat with the damaged prop. The outdrive is brand new and I don't want to damage it by putting undue stress on it. I am just tryin to figure out a good baseline prop to begin testing. I am not sure what the factory diameted prop should be and I am a little concerned the the diameter is too large.
Thanks for the Help,
John
