jamesbee19791
- Jul 1, 2017
- 10
Hi, I bought this boat about a month and a half ago. It's a 1996 Bayliner 2452, 5.7 Mercruiser with Alpha 1 gen II drive with a partial closed cooling system, manifolds are raw water cooled. This boat has seen mostly salt water use.
On the muffs it ran around 120 degrees before I bought it. Temp gauge is actually not accurate so I found. First trip out it stumbles an dies, seems to have overheated, let it cool down, it starts, I motor back to the dock and trailer it home.
Replace exhaust flappers and impeller, pull drive to check for flapper remnants in exhaust bellow. Fire it up on muffs, runs great. With an IR temp gun, starboard manifold is at 110 ish, thermostat housing about 145 to 150 then it drops. Seems good, shoot port manifold its at 215. I had the risers off when I changed the flappers, looked rusty and a water jacket was partially clogged. New manifolds and risers. starboard manifold is at 110 ish and port started climbing, I shut it down at 175. I pulled the drains on both and the port side had more water than the starboard side come out. Was thinking a clogged heat exchanger, but with the manifold draining water, am I over thinking this? I read a bit and understand they wont be the same temp, garden hose might not have enough pressure . Any thoughts? Thanks in advance
