I have a 1994 stingray 719zp that originally came with the 4.3 mercruiser. I have re-powered this summer with the 5.7 vortec long block. Everything is new, water circ pump, impeller in stern drive, intake manifold, exhaust manifolds, risers, thermostat housing with 140f thermostat, sensors in housing.
When the motor is running bellow 1500rpm the temps climb until it alarms. Above 1500rpm the temps start to come back down to normal. I have checked all the cooling hoses and they are obstruction free and I have great flow to the circ pump on the motor.
This problem existed with the previous motor, it seams as though there is a lot of back pressure in the exhaust and it is forcing exhaust back into the thermostat housing or I should say keeping water from flowing through the housing and spilling into the exhaust. I have replaced the exhaust flappers as well and there are no pieces stuck in the y pipe. With the exhaust elbows removed looking into the y-pipe the water sits almost to the top of the y pipe.
Could this be part of the reason why it has so much back pressure and does not allow water to flow out of the thermostat housing? I have gone through every past discussion on the site and others coming up with nothing. Any help would be greatly appreciated.
Thanks in advance!
Thanks in advance!
