tailwind 67
- Jun 24, 2005
- 34
I am in the process of rebuilding my engine. The thermostat housing required replacement. It is a seawater cooled open type system. I was told by the engine shop that Mecruiser changed the thermostat housing design. The new style is now the original style housing which I think is called a type 1. The housing I took off had a temp sensor at the 3 o'clock and 9 o'clock positions on the housing. The housing I just purchased and am trying to install, has holes for the sensors at the 3 o'clock and the 7 o'clock positions. The problem is that the one at the 7 o'clock position does not have enough room for the sensor to be installed. The intake manifold is too close. Has anyone run into this issue. This is the same housing that I earlier posted sticks out further to the front then the one I took off. This doesn't allow me to use the 12 o'clock hole in the water pump for my water heater tank return hose fitting but that is another issue. Right now I am focused on the temp sensors so I can get the housing installed. Thanks for any help
