SeaRaySalmon
- Feb 17, 2020
- 11
I have searched the internet and the forums and have not found the answer I am looking for.
I recently replaced the old TB IV ignition system with a delco voyager est. Engine is a mercruiser 5.7 vortec with 4 barrel holley carb and edelbrock intake. The boat ran great with the thunderbolt ignition and makes a ton of power but the module went and from what I searched online the delco voyager est was the best replacement.
Problem is the boat doesn't seem to have the power it used to. The only thing that has changed is the ignition system since the power loss. I set it to 8 degrees initial timing like the manual said (using the shunt and doing it correctly). I then tried 10 degrees initial timing to see if that would help and it didn't.
I have been using the boat and it's fine, I wakeboard on it and it runs well but this motor should make around 300 hp and it used to jump up on plane in seconds with the 4 blade prop and it just feels like a bit of a dog now..
Any ideas what the timing curve is on the delco voyager est module and what the timing curve of the TB IV module was? Anybody ever swap out the module on a delco voyager with a different curve? Where would I get a module with a different curve?
