Mercruiser 5.7L 260 - what's the real or entire serial number?
Blueghost924
Hi, I can't quite read all the letters/numbers off my Mercruiser 5.7L / 260 Alpha One. I have a 1987 Regal Ambassador 255XL, but since we (boat owners) tend to swap out motors, I can't attest to this being a 1987 5.7L as well. I know the attached pic of what I can see of the serial plate isn't the best, but any ideas as to what the entire serial number should be?
alldodge
Seeing 202234, being a 350, I would guess a 82 to 86 series and the first two would be 0B so 0B202234
achris
More fish than mountain goat
That's not a Merc serial number plate. I also tried all combinations of prefixes with '202234', '202231' and '202284' and none are an inboard/stern drive engine.
I suspect that plate is a rebuilders' plate, and pertains to an 'in-house' serial number system.
Can you take a picture of the front of the engine (stand back a bit) and we could get you a rough year...
Chris..........
Blueghost924
Gotcha. Here's a couple more pics that hopefully will shed some more light on the engine...
achris
Hi mount steering pump and 4" elbows, first generation TB-IV ignition amp module and 'Alpha One' drive put it at 1986...
flipbro
Master Chief Petty Officer
How many bolts holding the intake down? From the one pic it looks like mabe a vortec style intake. Looking at angle of front bolt.
Blueghost924
Ah thanks Chris. I've seen a couple of diagrams on the Mercruiser parts website in which the schematics are a match. Good to know.
Flip - not quite sure about the intake manifold. Looks like there's 2 bolts in the front and 2 bolts in the back. I don't know if it's a Vortec, but it has to go. A local marine mechanic said that it's an aluminum intake - and that it's coating my valves from wear particles (interaction with seawater) and causing problems with compression. I need to replace it with a cast iron one...soon!
achris
Aluminium manifold + marine engine = not a good ending... Even in a freshwater environment an ali manifold is not really a good option. The engine is still pulling in a lot of 'wet' air...
The easiest way to differentiate a vortec from a non-vortec is the angle of the manifold bolts. Vortec manifold bolts are vertical, non-vortec are cant at an angle.
Chris.....
