MerCruiser 5.7L Alpha -- Jackshaft Components -- replacing the bearings
jbutler67
Question about replacing the bearings on a jackshaft.
1986 Rampage 24 Express with 58" jackshaft
1998 Mercrusier 5.7
M048938
Looking for instructions on
1) replacing the bearing marked #17 in the attached (the one on the side of the jackshaft closest to the engine)
- Should it be pulled the same way one would pull the gimbal bearing? But using a different shaped puller up against the Shaft Extension Support housing cover?
2) replacing the bearings marked 34, 35, 36 in the attached (the ones closest to the transom/outdrive) inside the bearing housing assembly near the transom
Click image for larger version  Name:	Jackshaft -1.JPG Views:	2 Size:	73.5 KB ID:	10936558
alldodge
Bearing 17 comes out after snap ring 16 is removed. If its stuck a slide hammer my be needed
Procedures for removal, installation and alignment is in manual 9
