silverseal99
- Aug 9, 2019
- 16
Folks, I have a perplexing manifold/riser temperature/water flow issue that has me stumped. I don’t know if I am chasing a valid overheating issue or am within normal operating conditions and chasing a ghost. Below is a bit long but I tried to address all the “Have you tried…” issues up front. I am new to forums so if I commit some egregious error in protocol or procedure, please forgive me.
Issue: Seeing 30 F temperature differential between port and starboard risers (port side hotter) at idle whether in driveway or at the dock. Cooling water to and from the port riser burps and gurgles with about 30-50% air or exhaust gas mixed in. Peak temperatures at idle are 151 F at the port manifold, 119 F at the port riser, and 121 F at the port elbow. Increasing idle speed to 1200 rpm results in temperatures balancing to within 10 F port to starboard.
Questions:
1) Do I have a temperature issue or am I within specification?
2) Could a persistent “no fire” in #2 result in a 30F temperature differential port to starboard?
3) Is exhaust gas in the cooling water at the riser normal, or indicative of a cracked manifold that only manifests itself at operating temperature?
4) Should I invest limited funds to replace the manifolds or install an aftermarket closed cooling system instead?
Thanks in advance for your interest and informed recommendations.
GORY DETAIL
Background: During an initial sea trial in May 2019, the engine ran fine at idle and on plane but at WOT only pulled 3900 rpm. While at WOT, I smelled a hot engine, eased her back to idle and shut her down. Dash temperature gauge hit 200F. The set-up is a stock, raw water cooled, 2003 Mercruiser 5.7 Alpha/Bravo Carb (Ser. 0M634xxx) with 2 bbl Mercarb, dry joint manifolds and risers, less than 50 hours on the clock, and 100% saltwater use. Timing is set to 10 BTDC with purple/white wire disconnected. The engine is clean with no apparent exterior rust (either surface or at joints/gaskets) but was fresh water flushed (but not winterized) and stored on a trailer in SoCal for 15 years. In 2017, the boat was serviced (bellows, impeller, fluids, tune-up, etc), shop run, and assessed ready to operate by a local, respected marine repair shop specializing in Mercruiser products. Boat remained idle while hull/other maintenance was performed.
Assessment: Post-mortem revealed clogged jets in the carburetor (resolved), stuck thermostat (resolved), clogged water passages in manifolds (resolved), no fire in #2 cylinder (probably resolved although occasional backfire remains on startup), and persistent 30F temperature differential port to starboard. Measured raw water flow to thermostat housing exceeds threshold by 18% so “Bravoitis” has been ruled out. Suspect either cracked port manifold permitting exhaust in cooling water, or this is normal operation and I’m chasing a ghost.
Actions to date:
Questions:
GORY DETAIL
Actions to date:
- Manifolds and Risers: Removed and inspected. Bottom ports were clogged on the manifolds and the risers had some internal rust flakes. All were stripped, rodded, pressure washed, flow checked (garden hose), inspected (visually and with an endoscope), and re-installed with new gaskets. (A local machine shop assessed them to be clean and serviceable and that chemical boiling could do no better).
- Raw water pump: Rebuilt with new impeller and housing. Suction hose back-flushed from pump through out-drive. Supply hose back-flushed from thermostat housing to pump. Operational flow check yielded 10 quarts/15 sec at 1000 rpm pierside (exceeded spec).
- Power steering heat exchanger: back-flushed with garden hose.
- Thermostat: Housing is clear/clean with no rust. A new, tested good 140 F thermostat has been installed.
- Circulation pump: A new marine (SS backing plate, bronze impeller) circ pump was installed in 2017 with zero hours. It was removed, inspected, and reinstalled with new gaskets.
- Block: Water passages were flushed with a garden hose while the circ pump was removed. They flowed clear with no obstruction.
- Hoses: All hoses were checked clear and clog free. One soft manifold supply hose was replaced.
- Y-pipe and exhaust: Flowed clear from the flapper through the transom. Flappers, joints and elbows are clear and in good condition.
- Elbows: clear and clean with connections in good shape.
- Tune: Verified timing. Replaced spark plugs with AC MR43LT8. Checked spark to #2 with known good spark plug wire.
- Compression: Checked compression good at all 8 cylinders.
- Leak-down: Checked good (6% or less) at all 8 cylinders.
