Mercruiser 502
Formula24
What is the suggested idle RPM and cylinder compression (PSI) on the following engine:
1996 Mercruiser 502 Magnun 8.2L (Carburator)
Thanks.
Re: Mercruiser 502
Ayuh,....
Idle is 650rpms/ 750rpms.....
Compression should be even accross the board,...
150+psi is a New motor,...
Below 120psi is Worn Out....
