I own a 1997 Cobalt 220 with a Mercruiser 7.4LX EFI/MP engine. Mechanical fuel pump and Vapor Separation Tank (VST), does not have cool fuel. Love the engine, but on a hot day (central AL) after driving a while, stop for lunch or to swim, it will not start up. Does not happen in fall, winter, or spring.
I have seen the Mercruiser fix of adding a $1k+ electric fuel pump between the fuel tank and mechanical fuel pump, and read the Mercruiser maintenance bulletin about running the fan, opening the engine compartment, throw cool water on the fuel pump / fuel line, ect.
In the forums (iboat and others), I have not found anyone state that what they did fixed this problem for good. There is a post on iboat from 3 years ago with the same engine (my serial number is 100 units from that one), but no definite "this fixed the problem".
Has anyone had this problem and installed a fix for the VL issue on this engine?
Thank you for your help with this issue.
