Mercruiser 7.4LX MPI Throttle Position Sensor (TPS)
tpenfield
I got a TPS error code ( I think it was code 24) on my starboard engine (as I mentioned in my ECT Thread). I also got a MAP error code (I think it was code 33) I didn't write the codes down before I cleared them.
Anyway, I am seeing occasional high idle and surging from the starboard engine, so I'll go for the new sensors.
Mercruiser Part #'s are: (engine S/N's are in my sig below)
MAP: 864856A1
TPS: 805226A1
I know the MAP sensor is a GM part that you can get for a fraction of the Mercruiser price.
I believe the TPS is also a GM part. I have seen parts and pricing raging from about $10 to $90. I assume the really cheap versions are off-shore knock-offs, and the Mercruiser are just re-branded GM parts.
Just wondering if anyone has the GM cross-reference to the TPS part number, as I may try to source it by the GM number and not pay the 'marine price uplift'.
I have them linked at work, these are the ones i could quickly find with the phone
if you pull the sensor off, there should be ink-jetted part numbers on it as well. usually you can find the original manufacturer of the sensor that way.
tpenfield
Thanks Scott. I believe the code (24) indicates that the MEFI saw the TPS as being 'inactive'. So, maybe it is a connector issue, which I will check. Then I can probably get the #'s off the sensor.
tpenfield
According to my Mercruiser P/N searching, the TPS looks like this . . .
Click image for larger version  Name:	TPS-1.jpg Views:	1 Size:	11.2 KB ID:	10618369
I did not see any like images in the links, but maybe I need to look deeper into those web sites. I did see the eBay links. :thumb:
FITS THESE
Buick Century (96-93) Buick Commercial Chassis (93-91) Buick Roadmaster (93-91) Buick Skyhawk (89), (87) Cadillac Brougham (92-91) Cadillac Commercial Chassis (93-92) Cadillac Fleetwood (93) Chevrolet Astro (94-91) Chevrolet Aveo (05-04) Chevrolet B7 (98-93) Chevrolet Beretta (96-87) Chevrolet Blazer (94-91) Chevrolet C1500 (95-91) Chevrolet C1500 Suburban (95-92) Chevrolet C2500 (95-91) Chevrolet C2500 Suburban (95-92) Chevrolet C3500 (95-91) Chevrolet C3500HD (95-91) Chevrolet C60 Kodiak (96-90) Chevrolet C6500 Kodiak (98-97) Chevrolet C70 Kodiak (96-90) Chevrolet C7500 Kodiak (98-97) Chevrolet Camaro (95-91) Chevrolet Caprice (93-91) Chevrolet Cavalier (97-87) Chevrolet Chevy (07-02) Chevrolet Chevy Monza (03) Chevrolet Chevy Pickup (03-99) Chevrolet Commercial Chassis (92-91) Chevrolet Corsa (08-02) Chevrolet Corsica (96-87) Chevrolet G10 (95-91) Chevrolet G20 (95-91) Chevrolet G30 (96-91) Chevrolet K1500 (95-91) Chevrolet K1500 Suburban (95-92) Chevrolet K2500 (95-91) Chevrolet K2500 Suburban (95-92) Chevrolet K3500 (95-91) Chevrolet LLV (95-94) Chevrolet LUV (05-98) Chevrolet Lumina APV (95-91) Chevrolet Meriva (05-04) Chevrolet P30 (99-91) Chevrolet R1500 Suburban (91) Chevrolet R2500 Suburban (91) Chevrolet R3500 (91) Chevrolet S10 (97-91) Chevrolet S10 Blazer (94-91) Chevrolet Suburban 1500 (96-95) Chevrolet Tahoe (95) Chevrolet Tornado (05-04) Chevrolet V1500 Suburban (91) Chevrolet V3500 (91) Daewoo Lanos (02-99) Daewoo Leganza (02-99) Daewoo Nubira (02-99) GMC B7 (98-94) GMC C1500 (95-91) GMC C1500 Suburban (95-92) GMC C2500 (95-91) GMC C2500 Suburban (95-92) GMC C3500 (95-91) GMC C3500HD (95-91) GMC C6000 Topkick (96-90) GMC C6500 Topkick (98-97) GMC C7000 Topkick (96-90) GMC C7500 Topkick (98-97) GMC G1500 (95-91) GMC G2500 (95-91) GMC G3500 (96-91) GMC Jimmy (94-91) GMC K1500 (95-91) GMC K1500 Suburban (95-92) GMC K2500 (95-91) GMC K2500 Suburban (95-92) GMC K3500 (95-91) GMC P3500 (95-91) GMC R2500 Suburban (91) GMC R3500 (91) GMC S15 Jimmy (91) GMC Safari (94-91) GMC Sonoma (97-91) GMC Syclone (91) GMC V3500 (91) GMC Yukon (95-92) Isuzu Amigo (00-98) Isuzu Hombre (97-96) Isuzu NPR (95-93) Isuzu Pickup (92-91) Isuzu Rodeo (92-91), (03-98) Isuzu Rodeo Sport (03-01) Oldsmobile Bravada (94-91) Oldsmobile Custom Cruiser (92-91) Oldsmobile Cutlass Ciera (96-93) Oldsmobile Cutlass Cruiser (93-92) Oldsmobile Firenza (88-87) Oldsmobile Silhouette (94-91) Pontiac Firebird (95-91) Pontiac G3 (08) Pontiac Sunbird (94-92) Pontiac Sunfire (97-95) Pontiac Trans Sport (95-91) Suzuki Forenza (05-04) Suzuki Reno (05)
tpenfield
Yup, the TH42 cross matches to a 805226A1 per their literature. Looks like it is a $25 sensor
yes (you may find it for less). and I believe the IAC is a ford Windstar sensor. havent crossed the MAP yet.
alldodge
Great info I'm recording the stuff. Not to side track but does littlefuse have a cross reference section, I'm looking for a cam sensor
tpenfield
I was able to cross-reference the Mercruiser parts to SMP (Standard Motor Products) parts
MAP Sensor: Mercruiser 864856A1 = SMP AS5
TPS Mercruiser: 805226A1 = SMP TH42
Mercruiser pricing would be about $290 total. The SMP parts were about $65 total.
I got a few IAC modules as spares. It is the Ford Windstar part, as I recall.
tpenfield
UPDATE:
I put the new TPS in and ran the engine . . . FAIL :eek:
The engine runs at a high idle (1800 rpm) , so something is not right. I hooked up the Diacom and I was getting a 2.7 - 3.1% throttle position, which is off a bit. Should be 0% or 0.7%.
I did test the throttle movement via the Diacom (engine not running) and I am getting the throttle position to go up . . . about 85% at full throttle. I did a couple of IAC resets to not avail.
So, I am wondering if there is an adjustment or something :noidea: I believe the throttle plates are closed all the way, just the TPS is reading slightly differently.
I'm back at my house for lunch and will be going back out to the boat in a while to try again. Maybe I messed up putting things back together.
alldodge
There are set screws under the TB, but most cases they never need to be readjusted. I adjusted mine because it was damaged. Look at them and see if the potting around the nut is cracked.
tpenfield
Thanks AD. I got it sorted out.
There were 2 set screws. I was able to get the TP down to 1.2% with the set screw and then I was able to loosen the sensor, tweak it and re-tighten it to take out the rest. 0% 0.55Volts
Here is the Diacom readout . . .
Click image for larger version  Name:	tps1.png Views:	1 Size:	16.7 KB ID:	10623029
I then buttoned everything up and took the boat out for a spin. We have a big crew of people coming this weekend, and I was getting a bit concerned that I might have opened up a can of worms with the boat.
tpenfield
BTW - the original part was a 'CTS' brand sensor. Not sure if it is the 525 or 583 series.
