Mercruiser 888 Cracked Block or Head
jjohanson
Hi all, Sadly today I found milky oil in my mercruiser 888 ford 302. So my question is, if the block is cracked is there an automotive ford 302 shortblock I could swap into it? What year to year if possible? Just want to get a little info before I start tearing into this thing if its even worth it. Thank you
Re: Mercruiser 888 Cracked Block or Head
Ayuh,.... I donno the vintage mixin', 'n matchin' Gotcha's on Fords,...
But a Ford 302 pickup motor of the right vintage will No doubt get ya goin'.....
'n I'd go for a Long block, as you don't know whether yer heads are any good, or Not...
Just pop in some brass core plugs, 'n bolt on yer accessories...
jjohanson
Thanks for the response, I have decided to fix instead of letting it go. Anyone else know the year range the replacement block needs to be? The boat is a 77 on the title
jjohanson
Also, if the heads are in bad shape, since it has 351w heads do i have to replace them with the same 351w or will everything bolt up to the standard 302 heads?
Piratehooker
Maybe a ford guy can chime in, but the bolt pattern on the back of a 302 should be the same no matter what year. I would think any of your worries would pertain more to being able to bolt up your accessories. You would prob want a carb'd engine, but even one of the newer 5.0 blocks could work. The 302 has really been the same for a long time bare bones wise.
haulnazz15
Any year 302 will work, but you will have to get a different harmonic balancer/flywheel to match if you go with a later engine. I can't remember what year they changed the imbalance, but it was late 80's I think. The heads are pretty much interchangeable, but the bolt size is different for 351w.
