Greetings wise ones’
I have a very nice running ‘72 Mercruiser 888/Ford 302.
I’m using 93 octane religiously adding Stable Marine at every top off and an occasional Sea Foam additive treatment as well to counteract some of the Ethanol. Had the boat 6 Years and am having to rebuild the carb now a third time. Here’s my questions
1. How often do these old Hollys need to be rebuilt?
2. This system utilized a glass bowl sediment filter along with a separate canister water separation filter. I’m remote from the boat right now but was wondering do you know if there should be a paper filter within the sediment bowl? Just hit me that I’ve never seen one in there
3. Can you foresee any issues if I were to add an inline filter to this system between the tank and the sediment bowl? I’m OK if this would be overkill - but want to be sure it wouldn’t impede any necessary fuel flow or pressure if I purchased the correct one.
Thanks in advance
CT
Thanks in advance
CT
