Mercruiser 888 starter
adice67
I have a 1976 Bonanza 18 foot with a mercruiser 888 Ford 302. I have had it running a few times and been repairing problems from the person I purchased it from. He didn't winterize it last year. Had the freeze plugs replaced and the exhaust manifolds replaced because they were cracked. Now when I turn it over it cranks but when it sounds like it wants to start the starter disengages and spins. I replaced the solenoid thinking that might be part of the problem but the same thing happens. What should I be looking for to solve this issue. When I had it running it ran great. This just started after replacing the manifolds.
Stevens520
Re: Mercruiser 888 starter
I had the same issue with mine this past spring, and traced the problem back to a dead battery.The starter battery was dead, so PO switched the deep cycle battery over to the #1 position so it would start. If that fails, pull the starter and makes sure no teeth are missing from the flywheel.Start with the simple stuff first.
Ayuh,.... Welcome Aboard,.... Have a read Here,..
it's found up in the Adults Only section, at the top of this forum,...
Follow the steps Don has lain out, 'n you'll have the answer to yer starter questions,... ;)
