Hi all, Been having some trouble getting my mercruiser 888 running so I thought I would post here for help. Recently replaced the intake manifold since I found a crack. Also, recently replaced was the spark plugs, cap, rotor, fuel pump, and carburetor(brand new). Checked compression, spark and fuel pressure and all three were good. When I did the intake manifold I had to remove the distributor so when I put it back in I put my compression tester on the #1 cylinder(facing pulley side of engine first left correct?) brought it to 6 degrees BTDC and placed the distributor back in and facing the #1 plug wire. A couple times I have gotten it to fire up but for only a few seconds. Anyone see something I'm doing wrong or have any ideas?
Also, I was thinking of replacing the distributor to something more up to date without points/condensor like this:
Distributor Ford V8 302 Electronic LH
but it says it require this coil:
Coil | Ignition | Mallory
Which my engine is not listed on the application chart. Would these work? I know nothing about converting this and the difference between coils with internal/external resistors. Maybe someone can help me with this also
points suck
