mercruiser 898 shut down
grosbob
hi. i have a 1980 glastron adventura with a mercruiser 898. my motor stop for no reason and there no more power when i turn the switch to on. any idea.
Bt Doctur
Re: mercruiser 898 shut down
battery, battery cables, battery cable ends, corrosion where cables attach,90A fuse on starter.
some history, what was it doing, what were you doing when it stopped?
Ayuh,.... Welcome Aboard,... Is the carb feedin' the motor gas,..??
Is there Power at the coil's (+) terminal with the key "On",..??
grosbob
i was ridding at low speed and at first my gps shut down for no reason. the thing is that when i shut down my boat the gps always stay on. i start the gps back and like 5 min after the gps and the motor shut down. no temp alarm oil pressure was good electric power at 14. i tried to start the engine but when i turn the key nothing. like there no more electicity. could it be the alternator. tomorow i will go check for courant.
alldodge
Check your battery connections and where they connect to the block and starter. You have a bad connection somewhere as Bondo and BT doc mentioned
