mercruiser Alpha 1 140 hp water leaking from hole in cold water supply housing
charlie Noble
Have mercruiser Alpha one 140 hp that has started leaking from a hole in cold water supply housing that is leaking into bilge when engine is a rest.
Is there a frost plug that should be in the hole which is close to the rubber
intake hose?l:confused:
Re: mercruiser Alpha 1 140 hp water leaking from hole in cold water supply housing
Ayuh,... What Housing ya talkin' about,..??
charlie Noble
On housing on stern drive with rubber hose that leads to engine
Ayuh,... At the Transom,..??
The Bellows is Ripped,+ Leakin',... pull the Drive to Inspect it...
charlie Noble
Yes the leak is at the transom
Then you probably need New Bellows...
