Mercruiser Alpha 1 Gen 2 Impeller Kit
Status
Not open for further replies.
tkarvelis
I am looking for the correct impeller kit for my Gen 2 out drive. The serial number is 0d899455, I have seen many part numbers and the all say they will work, but I am not sure. I am willing to get an aftermarket kit also if they are safe to use.
Fun Times
You're looking for water pump kit part number 817275Q05 or 817275K05. Both them numbers come with a new impeller housing.
If you don't want or need a new housing then kit number 47-43026K06 will do.
Unfortunately there doesn't seem to be an aftermarket kit matching these numbers.
Hope this helps, good luck.:)
vsok
What is the difference between the 817275Q05 and 817275K05 kits? Are they the same exact parts or are they equivalent parts from different manufacturers?
Fun Times
Hi there vsok , Welcome to iboats...First please know it's always recommended to create a new topic of your own vs bring up an archived topic that becomes older than 90 days.
To quickly help with your question though....The only difference between the two part numbers is the branding package/container box each one comes in but both are a product of Mercruiser....One name brand is Quicksilver (Q) that comes in a silver package while the (K) letter/number comes in a Red/Black package.....Other than that there is no differences in parts.
https://www.ebay.com/itm/Mercury-OE...m=R40&rt=nc&_trksid=m570.l1313&LH_TitleDesc=0
https://www.ebay.com/itm/New-Mercury...d=280571460588
All that mentioned it looks like aftermarket Sierra Marine part number 18-3147 replaces Merc/Quicksilver Water Pump Kit # 817275k05...., http://ww2.iboats.com/Sierra-18-3147...view_id.172768
Status
