Panoguy
- Jul 29, 2011
- 150
I have a 5.7L crate engine attached to an old (used to be white... that old!) Sea Ray upper unit (gear ratio=1.47), that looks pristine inside, which in-turn is attached to a new SEI-106 lower unit. First time I splashed the several weeks backboat, all worked well - it would shift into/out-of Forward/neutral/Reverse without issue. 2nd. time (last weekend) & 3rd time (today) - Troubles!
The boat would shift-into whatever gear I needed, but would then be stuck there, unless I turned-off the engine... then it would go into neutral to start, & shift into either forward or reverse, but again remain stuck into that gear till I once-again shut-down the engine.
All shifts fine in the driveway, with the earmuffs on.
I read Don S. post on the shift interruption system... am wondering if this could be my problem, but honestly, am at a loss here as if it is/to how to fix.
Any thoughts?
Any thoughts?
