MerCruiser Alpha drive power tilt leak
Mach 1
I have an OILDYNE floor mounted power trim pump on my MerCruiser Alpha Drive. The pump in mounted behind the engine making difficult to view much less work on. My question is the pump has a very slow leak but I can’t find it anywhere. Do you have any ideas on how to locate the leak and repair it? Are the OILDYNE pumps known for leaking? If you are not familiar with the<br />pump go to this link www.sterndrives.com/bulletins/mc/91/EN_014.PDF.
