I have an 84 Sea Ray 23' cuddy. The engine is a 5.7 260hp Mercruiser with a 1st gen Alpha 1. The gear ratio on the current drive is 1.47. I'm replacing the entire drive and I found a 1st gen Alpha 1 that is a new drive and a good price, but the gear ratio is 1.62:1. The seller says there will be no change in cruising rpm/efficiency, hole shot or top end if I run a smaller pitch prop. I currently have an aluminum 19". He's suggesting 16"...
Anyway, if prop pitch/diameter can make all things equal then I'll buy it. If not I'm looking at an SE106 in the 1.47 ratio.
Thanks in advance for any input!
