Jellybelly
- Aug 3, 2020
- 5
I am helping a coworkers husband rebuild a 1973 sea ray. It has a straight six165hp Chevy engine. I recently replaced the water pump. I never did find the right base and just reused the old one. It was a short and stubby one without a gasket.
Here is a picture of the lower unit. I think it was a replacement lowers perhaps because I’m not sure the square was used then. It does not have the preloaded pin. Now I know what that is.
When we put it all back together, We struggled to get the lower up close to the mid section. Having never done one this old, I thought maybe it was normal. Probably over an inch apart.
we snugged them up evenly but the shift would not return to neutral or go to reverse. I was pretty certain the prop and the lower and upper were in forward. So, I removed the lower again. I had done my best to rotate the prop and keep it in forward. Obviously I must not have done so or screwed some other way.
while mating the lower to the upper The first time, I likely stripped the intermediate Brass shift shaft. There were brass shavings when I took the lower off to try again. No problem, new one is cheap. Looks easy to install too. This time When I reinstall, I’m removing the upper housing too.
but more troubling is the lower unit shift shaft will not turn with my fingers. I can turn it with pliers easily. Is this ok? I remembered before I did the stupid misalign that the shift arm turned easily. Maybe it was as I moved prop. Long day. I am afraid maybe the force of misaligned shift shaft may have damaged it. I can get the lower into forward and reverse with the pliers and turn the prop and it seems to be engaging with a click. I am really hating that I offered to help.
any help would be appreciated. If I have to buy him a new used lower I will. I should have know better. My experience is all in outboards. Not much different down there, but never a mercury.
