Hi All, I've got an older (84) Mercruiser IO with an Alpha drive that has been having shift problems for some time. Original shift problems ranged from the kill switch activating when you gave the boat too much forward throttle to killing the boat in reverse. Since I figured this boat has never had a bellows service I've owned the boat for 20 years and suspect the previous owner never did this either.(he was the original owner). Figuring the lower shift cable needing replacing anyway I dove in a few months ago and replaced all the bellows (man, that was a nightmware), put in a new gimbal bearing (another nightmare as the old one didn't want to come out so had to cut it out), bought an alignment tool and aligned things, and put in a new lower shift cable, new bellows, new gimbal bearing etc.).
After getting everything back together, I can't shift. Basically the same problem as before I started this exercise. Seems like there is something to be learned here about spending more time troubleshooting the actual problem before diving in and replacing things
(The old bellows were pristine as was the old gimbal bearing by the way).
Removing the lower shift cable from the engine, I can get this into reverse ok but forward rarely engages. It's as if the cable doesn't have enough forward throw when I shove the cable all the way in . Looking at the shift shaft shoe (under the outdrive), I don't see that it is completely facing forward (appears to be at about 11 o'clock instead of 12 o'clock which is what I'd expect). Hmmm. I did replace the impellor on this outdrive a couple of years ago...it is possible to not align the shift shaft correctly when bolting the lower unit to the upper gear housing? I see some warnings implied to this effect in my Seloc service manual so I'm wondering if maybe all this started when I did the water pump impellor service.
This one has me stumped.
