Hi
Im rebuilding a boat and currently building a driveline for it.The engine is almost finished and the transom housing has been completely rebuilt.I aquired a alpha one 1.5 outdrive from 1989.The outdrive was leaking oil to the bellow so I got it for cheap.Since the drive is all original from 1989 I thought a partial reseal might do good.
I replaced the complete waterpump,shift shaft seal and bushing,vertical shaft lower seal.Will still need to change the o-rings and oil seal on the u-joint that was leaking oil.Still dont know if I let the shop do it or if I buy a torque gauge which is needed to set the bearings.
Anyways I know the later modell alphas have a drive oil reservoir and I would like to get one myself.I have already built a bottle with bracket and thru hull fitting out of 316 stainless steel.My first thought was to replace the top oil plug with a hose connector.Is there something wrong to attach the drive oil reservoir at this height of the drive.There will still be left the airpocket at the top part of the drive just as the drives without oil reservoirs.
I really dont know how its done from the factory on the gen 2 drives,and a bit keen to find out.From what ive gathered the oil goes by hose throught the transom housing?Any input is greatly appreciated.Is the complete outdrive filled on the gen2 or do they also leave a air pocket at the top housing?
