donn nelson
- Feb 7, 2004
- 2
This boat has been run in salt water for only the most recent 1-hour of its life. I took it down to Florida only a month ago- the remainder of its life has been at the Lake of the Ozarks in central Missouri. The boat has only 360 hours on it and was owned by an 80-year old gentleman before I bought it 6-months ago. I'm wondering if something failed due to the 12oo-mile trailering. Once again, the hole I am speaking of is just portside of the casting to which the "radiator hose" is connected and at the same level on the transom housing as the 2 upper bolts that bolt-thru to hold the outdrive. I am mentioning this in lieu of the picture- which is a much better idea, however, we are back in Missouri and the boat is in Florida.Thanks for the info. So, what about the idea of putting a bolt in that hole as a temporary fix? By doing so, will it cause additional damage? I have a 1987 Celebrity 210 with a 260 Mercruiser and Alpha One Drive. On the housing which attaches to the inside of the transom, just to the port side of the casting where the approx. 1.5 inch radiator hose connects to this housing is a small hole the size of a pencil eraser which appears to be threaded, is now allowing water to enter the bilge area. When the engine is not turned on, the water trickles in; when the engine is running, it is coming in at a greater volume. This just started; I do not believe there was a bolt that fell-out of this hole. Any ideas? If I put a bolt in this hole to stop the water running in, will that cause another problem? More importantly, what is the source/ reason for failure causing this water to now come in through this hole? Thanks for the help.
