donn nelson
- Feb 7, 2004
- 2
Follow-up to mine of 2/8- in the meantime, while I am attempting to determine the actual cause of the water coming in thru the small hole just to port of the radiator hose on the transom housing and at the same height as the top bolts thru the transom holding-up the outdrive, would it hurt to screw a bolt into the hole to stop the water from coming into the bilge? Would this cause any more damage to what is already done? Wouldn't it just force the water to exit out of the outdrive?
