CaptnKingfisher
- May 14, 2017
- 262
First time working on this outdrive.. it's a friend's boat.. everything was working normal, then one day boat overheats. I come over and replace the impeller and replace gaskets and orings, had the service manual at my side and pretty sure I did most everything correctly, one thing I skimped on.. I didn't have gasket sealer to use on the top of the base gasket. Anyway I noticed the water pump guide tube which has a bend in it looked deformed, wish I'd taken a picture of it but it's shape definitely restricts the flow (inner diameter is significantly smaller almost looks like it was crimped rather than a typical bend like I'd have expected to see). Put everything back together without issue then disconnected the transom hose from the water pump at the thermostat. I poured some soapy water down the hose to lubricate the impeller then I started the engine on muffs. No water came out the transom hose with the engine running. I shut it off, took off the hose and cleaned it but there were no obstructions.
My game plan is to replace the water pump guide tube. I'm thinking I must've damaged it when I was removing the lower? Or somehow it got damaged during operation.. idk what else comes to mind that I should check?
The old impeller was pretty mishapen. I've got in my truck I can post a pic.. but it doesn't seem to be missing any pieces that would be obstructing flow. Any other things I should try or could have messed up? I've changed plenty of impellers on outboards so I felt comfortable with what I did, however when I take it apart to install the guide tube I will double check everything and post pics
