I was hoping to get some ideas on what my shifting problem might be due to. I have a single lever quicksilver shifter. My problem occurred when shifting into reverse - I had a bit of a tough time getting it back into neutral the other day -kinda nerve racking. I'm thinking either the shift cable that runs to the outdrive is sticking and needs to be replaced and/ or the adjuster near the kill switch needs some tinkering with -watcha think fellas? When I turn on the engine -i let the boat engine warm up a bit about 5 minutes next I generally put her in gear -no problem but sometimes shes a little slow to go back to neutral and then a bit slow to get into drive. What do you guys think?
