Mercruiser alpha one outdrive
cenzo
When running with water ear-muffs, a continuous, hard stream of water was coming out of the gearhouse water drain hole. Is this normal? I don't recall it being this way while running. Could I have over-pressurized it with the hose before starting the motor?
crazy charlie
Re: Mercruiser alpha one outdrive
Sounds right to me.If there were "too much pressure" it would come out of the muffs.
Don S
Which "Drain Hole" are you referring to, there are several.
cenzo
The steady stream is coming from the lower unit out of the gearcase housing weep hole.
KRS
Banned
I believe it's normal.... DonS will know :)
