Was on a ride on the 4th of July, must have hit a shallow spot and bottomed out. After putting it in neutral and back in forward, prop would spin, but wouldn't go anywhere. Increased throttle and no increase in prop turn. Got a tow back in. After getting the boat on the lift, the prop turned freely. I then tried to remove the prop. Problem is that with the prop held in place with a piece of wood against the anti-cavitation plate, turning the nut to the left also turns the prop shaft, so I wasn't able to get the nut off.
Any suggestions or recommendations? Let me know if I can provide any other useful info. Thanks.
Chris
Chris
