The outdrive will go all the way down and there on slack...locks in place. Can raise it up and down in any position. The up limit switch works also. The problem is when you hit the bypass button to raise it all the way up the out drive locks in the up position and want come down. If you push the down button hyd unit runs but it want lower. If I break loose any hyd hose on the two lift cylinders and bleed the smallest amount of hyd fluid it will start working (I'm talking about two drops) any help would be appreciated Thanks
