Goldie627
- Oct 28, 2013
- 1,010
Hey all, at the end of last year I pulled my motor for a makeover. I finally get the motor back together and installed, check my alignment (its good), and cant get the dad gummed outdrive to go on all the way. Its about a inch, maybe inch and a quarter out. Its not binding by the shift shaft, it seems to be binding above that area like maybe near the universal joints. Ive been restoring my boat for almost 5 years so im not a total noob (im more like a partial noob!), but im stumped... This is how I install the out drive.
Bribe one of the kids to get in the boat and put it in neutral (im lazy
Apply grease to the shift cable and roller that's in the bellhousing.
Apply grease to the outdrive housing, yoke splines and o-ring in the bellhousing,
Apply oil to the 2 o-rings on the yoke that are close to each other
Psych myself out to lift that heavy *** outdrive
Offer the outdrive to the bell housing moving it on slowly
Stops moving about 2 inches or so from mating
Simultaneously spinning the intermediate shift shaft while spinning the prop counterclockwise the prop will lock
Now in forward gear the intermediate shift shaft and the shoe will be in alignment
(i double check getting on the ground with a flashlight)
I spin the prop counterclockwise with 2 hands or step on a prop blade just a wee bit and the splines will line up allowing the out drive to go on further
and well there am:facepalm: 1 inch away from going fishing!!! plus im on staycation this week!!
im in forward gear
lower cable is lined up and not binding at all in the outdrive
lubed up
tried with front of the boat down, up and horizontal
are my universal joints bumping my gimbal out of place?
I did notice that my gimbal bearing didn't appear to be tight, i could move it by hand. with the alignment bar it rotates smooth no grinding... plus gimbal bearing only has a few months usage on it.
Im stumped...
im in forward gear
lubed up
Im stumped...
