Mercruiser Alternator Issues and Wiring
landover50
I've got a Mercruiser 5.7/V8 Alpha One Thunderbolt engine, serial number 0C764258 with a Mando #AR-150 alternator. The boat is over 30 years old and I'm guessing this is the original alternator.
I was on a fishing trip this last weekend and had charged the battery prior to leaving. I was running the engine intermittently to ensure I was charging the battery but it died (while night fishing with 3 kids, turned out to be an interesting nigh :) ) I was running some LED lights and a fish finder but not for that long. It got me wondering if my alternator was doing it's job. I tested the voltage at the battery while running and was only getting 12v. So I revved the engine and still only got 12v. While revving the engine I was inspecting the alternator and the noticed one of the washers on the positive terminal turning/glowing red in a spot. There are a number of washers and nuts on that post and they were all pretty loose, not tightened down. So I decided to to pull them off and give them a good clean before re-tightening. The first nut was rusted pretty good and when I turned it, it twisted the end of the bolt/post right off. But there was one other nut so figured I could use it to tighten everything down. I pulled all the washers/nut and cleaned them. I also cleaned off the connection from the condenser as well as the orange wire connection. But when I put it all back together it instantly started to turn red and started a mini fire, melting the connection from the condenser and welding the first washer to the alternator. You can see in the pic that the round connector from the condenser is melted half off. My question is, what did I do wrong? All the wires were connected to that post previously, doesn't seem like I put a wire where it shouldn't be. Did I do something wrong or could it be a problem internal to the alternator? I plan on getting it rebuilt or buying a new one and want to make sure I don't do anything wrong when putting it back together.
Also, while doing a quick inspection of the wiring harness I noticed a black wire coming from the main bundle out toward the breaker/starter slave solenoid that isn't connected to anything. Without tearing apart the main bundle I don't know where this is coming from/going and don't know where it should be connected. Being a black wire it seems like it would just be a ground but not sure where it should be attached to, shown in picture attached. Any help on these two issues would be appreciated. Thanks.
alldodge
The Black is a ground, and I would install it under one of the nuts holding the slave relay in place. It may have been removed before and not reinstalled. Could have also been at another location, but it needs to be grounded to the block. With a bad ground it can cause the ALT to over charge
Looking at your pic, it looks like the Red and Black wires are swapped. If it is then the Bat was shorted to ground. Your motor didn't come with the 90 or 120 amp fuse, otherwise it would have blown first. Might want to install one on the orange wire. The fuse bolts to the starter post, then orange wire gets attached to the smaller post6
Fuse
landover50
Just to make sure I'm in the same page, I've attached another pic with the wires numbered.
1. Orange, connected to positive stud on alternator
2. Big black, ground, connected to neg stud
3. Red w/purple line,
4. Black (not sure why it's black but it connects to purple)
5. Small black, goes from back of alternator and connects to neg stud
6. Small black (has the melted connector) goes from bottom of condenser to positive stud
I don't think the wires are switched. I've had the boat for a couple years, seems like crossing those two would have caused major issues, but not sure. Main question is why did connecting the wires back to the pos stud cause such issues?
Also attached is a pic of the starter where the diagram shows the fuse, I don't believe I have one. Does it have to be installed at the starter?
alldodge
Your number 2 should be ALT to Bat (orange wire) from where I see it being a Mando ALT
landover50
Do you have a wiring diagram somewhere showing the Mando specifically? It seems like if I had the ALT to Bat and the ground backwards I would have had major issues before my recent issues.
alldodge
Guess I don't understand the comment. The pics above "are" mando ALT
Here are different ones including 2 different Mando's
