Mercruiser Batwing manifold/riser Replacement -- When ? (as preventative maintenance)
Status
Not open for further replies.
garycinn
I have a 2001 Bryant 196 w/ 4.3L TBI. Being a 7 year-old boat with 300 hours in fresh water (raw water cooled), when should I start worrying about replacing these 'wonderful' batwing manifolds with the standard two-piece manifolds? Now, 400, 500 hours; 10 years? The thing runs like a top, but I plan on keeping her for a while and don't want it to fail and ruin the engine.
Should I take them off (never been off -- I know, I probably should have by now) and inspect? I am just now putting in new plugs at the end of this season.
If I did replace the batwings, I would get the conversion kit so I wouldn't have to replace the Y-pipe / pull the engine.
If I don't replace the batwings now, should I inspect the shutters now after 7 years? I'm a little nervous about shutters b/c I helped a colleague change his water pump impeller on a '94 Alpha and found a couple of shutter halves in the exhaust chamber.
Any suggestions are welcome.
Thanks.
chiefalen
Re: Mercruiser Batwing manifold/riser Replacement -- When ? (as preventative maintena
What temp does it run at?
Fresh water got me could go 20 years, mine 23 years old, salt water i had to change the riser when i got it.
First time it goes anywhere near 180 than you know it's time for a riser.
How about your impeller in the drive?
How about your t-stat?
When were those looked at changed?
How about your rubber on the drive?
How about your out drive oil?
garycinn
Chief,
I think it has a Merc 180 stat, so it runs that or just under most of the time; never seems to wander. I change the impeller every other year (doing it again this year); t-stat is good, replaced it about two years ago when winterizing; drive oil is good -- never water and changed every year w/ Merc Gear+ oil.
The bellows seem good. No cracks, I store the drive down during the season and off-season. I know I am probably due around the 10 year mark just as a precaution.
Ayuh,...
Personal experince,...
A Bud had a set on his boat, he blew up the motor, we shoe horned a 350 into it's place....
I give the Batwings to another Bud who builds boats from the Junk Parts pile....
Now he's rebuilding his motor because of water ingestion....
Bent Rods,+ All...
Those were freshwater run with unknown hours....
Personally,...
I'd do the conversion kit as Soon as I laid eyes on'em...
chiefalen
Woa 180 t-stat?
abj87
160 it the max for raw water cooling
Status
