Attached is photo I took of one of my Bravo 1 transom back plates. It's been cleaned up and panted gray epoxy where there was some surface corrosion. I just noticed that there is a gap of about 1/8" between end of metal ruler and surface of transom plate. It is hard to see gap on photo. The rest of the plate is flat. Is this gap normal? When I torque all 8 nuts, this curve would add constant pressure against nuts/bolts, which may be needed. I have never really noticed these very slight curves in lower part of back plates, but I have never tried looking for them. These maybe normal or required for positive pressure? My gimbal housings are flat. Any advise would be appreciated.
