- Jul 18, 2011
- 18,285
It has been about 7 years since I did any major work on the outdrive. So, today, I figured what the heck, and ground the paint and primer off down to the metal.
My plan is to do a a anti-corrosive primer and re-paint. Before I do that I want to take care of some pitted areas from some corrosion, etc. (previous owner neglect, long story)
When I re-furbed the outdrive about 7 years ago, I used a general purpose epoxy to fill in the pitted areas. It worked OK, but this time I would like to use something a bit better. Here is a picture below of the outdrive after the initial grinding. You can see some of the pitted areas as well as some of the epoxy from 7 years ago.
What type/brand of filler would work best for filling and fairing of the pitted areas of the outdrive housing?
Thanks in advance for any recommendations. . . I plan on using Interlux outdrive primer and then an enamel top coat (gloss black). Finally, an Interlux clear gloss anti-fouling paint.
I still have some POR15 Engine enamel left from the engine re-build this past fall . . . I am wondering if that might be a good choice for the outdrive color coat ???
P.S. I know the skeg looks like crap . . . I have a stainless steel "skeggard" to go over it.
