Mercruiser cooling problem
jpopp
Have 1985 Chris Craft with typical small block 350 and I believe an Alpha one outdrive. Went to start up boat after sitting for winter. Drained antifreeze out and hooked ears up to it. Motor started but would not take water up and started to smoke so turned it off. Poured water into exhaust hoses, hooked up ears and started again. Still didn't take water up or discharge water but was fine for awhile, but then started to smoke kind of bad out of exhaust ports it looked like. What is up, why won't it take water up, or discharge any water. Did discharge water as pouring in hoses I am assuming when I got too much in, it opened up the exhaust flaps.
outboardguy
Re: Mercruiser cooling problem
Check and replace your water pump impeller in your drive.
hondon
That water pump impeller is a regular maintenance item .If you do'nt know when it was last changed,or if it ever has ,or you have had a dry run, you are way over due.A good place to start.
jpopp
Before ripping into impeller, would like to know if there really is problem. Temp gauge never climbed up, so assuming thermostat never opened to get water in. Is that right or should water be flowing through system all the time. Only water that came out of exhaust was when I was filling hoses with water. Plus, can't get to thermostat, bolts are seized up in housing, not quite sure what to do.
achris
More fish than mountain goat
For temperature gauge to show a reading, water must be around the sender. If there's no water in the system, then the only way the heat will get to the sender is as the block heats up. For enough heat to get up the water block (on the front of the engine) your motor would have to be red hot, quite literally glowing! If it's been in storage for a while and it's not pumping water the FIRST place to start is the impeller in the leg.<br /><br />The system is set up so water is pumped into the block (even if it's empty) and held there until it's hot enough to open the thermostat. <br /><br />Chris.........<br /><br />If you want a water flow diagram, let me know.
