Have '85 I/O with I-MR drive, started engine with muffs on, didn't appear that water was being pulled up through outdrive so I replaced impeller and housing, which looked pretty bad. Tried it again today and still not pulling water up. Accidentally did it with both hoses off of thermostat housing and was able to observe that no water was getting to the housing. Is that the path it takes. It gets pulled through the intake by the impeller and waits atop the thermostat until it opens. But where does the actual water pump that is attached to the front of the engine, come into play. Once the thermostat opens does it then pump water through the block or does it pull the water to the thermostat. Any suggestions as to what I should do next.
