Mercruiser crack
areff
My 1987 mercruiser stopped suddenly. I tok off the alternator as it failed to turn. I replaced it. Still no luck starteing. Several people have told me it sounds like something else seized up. I trid to turn the crankshaft with a breaker bar. No luck. I was told to remove the plugs and try. As I was removing the wires I noticed a big crack on the side of the engine with rusted water dripping down the ide. Do I need a new engine? it is a v8 260 h.p.
flashback
Re: Mercruiser crack
yep, do a search on cracked block or water in oil, and you will have a few days reading..by the way, welcome to I-boats.....good luck
Tufan
You maybe able to get that crack fixed, If the crankshaft turns, your engine is not frozen <br />-good news- you should find out how deep is your problem.
highaltitude
if there is water in the motor oil you will need a new block-the internal passageways are cracked and cannot be welded or patched.
